Twins with cheap turbo?
Old 09-14-2007 | 10:33 PM
squirrel's Avatar
I managed to get a hold of a turbo from work for the cost of scrap metal and i would like to know if it is big enough to go under my pdr hx35/14wg? Dont know what it came off of because i found it on a pallet. The intake wheel is 67mm and the exhaust wheel is about 75mm i say about because i cant get the calipers in there with the exhaust housing on. On the intake side it says Air Research. The exhaust housing reads 1.21 AR.
Old 09-14-2007 | 10:51 PM
schoust's Avatar
I would not do it! Unless you know what you have and you can fab all the parts that you need don't bother! I just cheaped out on a used Hx40 that I was warned not to buy and I did anyway and I could;nt get thing to work at all! my next turbo will be new and a Name that I can count on.
Old 09-14-2007 | 10:59 PM
PourinDiesel's Avatar
Post a picture....
Old 09-15-2007 | 12:56 AM
HOHN's Avatar
AirResearch i a Garrett brand.
67mm is too small to make it worth the hassle of fabbing twins, imo. I'd personally want at least 73mm on the inducer to make it worthwhile-- nothing special about that number, but good singles are out there up to 71mm or so.
jmo
dodgediesel
ABDTR #5
10-18-2011 10:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 05:33 PM
dodgediesel
17
04-05-2011 12:21 PM
Common
06-01-2008 07:15 AM
Stock 02
28
09-24-2006 12:09 PM
Quick Reply: Twins with cheap turbo?
