Twins
Old 03-04-2006 | 11:46 PM
24valver's Avatar
Twins
Hey guys every time i think im done with my truck i just cant help to want to do more. I want to put twins on my truck but i want to take time and try to do the piping and everything by myself. I allreay have a super 40. Im a daily driver so i need something for street use. Any suggestions.
Old 03-05-2006 | 01:56 AM
hotmopr's Avatar
I would use a s400 for the bottom. The S400s spool faster than a HT3B. Although 3Bs can be found fairly cheap between $250-400 for a really good one. Talk to Rip at sourceautomotive.biz. He sells almost everything you will need to build your own set-up..
Old 03-05-2006 | 04:05 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
S400 bottom and a good hx35/12 or 14 wg hybrid top is a great combo i see 1200 egts max. the 12 spool up is faster but i think i may drop to a 14 when i step up to a better clutch and bump the hp and hopefully the aditional flow will slop down the primary and help get a little more exhaust to the secondary
my tubing parts and pieces came from rip, i orderd one of his kits this go around. after building a couple of sets previously and fighting the agrivation of in and out, exhaust leaks and the ocassional poor weld pin hole leak. for this truck i decided to go with someone elses. his price was right on key for the tubing and all other parts and pieces i needed. i had the S400 already but even his price for the kit with the s400 is considerably less than other options.
the kits was very complete, instructions were a little vague but any kind of kit even pdr kit the instructions are vague. your better off laying it all out aseembling in outsid ethe truck getting things as close as you can then (possibly using a spare engien to get it all mocked up then dropping it in) The collant lines he provided i didnt need to use but the fit and finish of everything else was top notch. figure a full day for install.
Old 03-05-2006 | 04:13 PM
Willy91's Avatar
Does Rip have a website?
Old 03-05-2006 | 04:41 PM
rockjeep73's Avatar
http://www.sourceautomotive.biz/
Old 03-05-2006 | 09:59 PM
24valver's Avatar
is the s400 better than a HT3B??
Old 03-05-2006 | 10:04 PM
TxDiesel007's Avatar
It is said
that it flows more air and spools up faster.. So that would be a yes...
Tx
Old 03-06-2006 | 12:47 AM
ddestruel's Avatar
ht3b 1150 cfm
s400 1500 cfm
IIRC
dodgediesel
ABDTR #5
10-18-2011 10:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 05:33 PM
dodgediesel
17
04-05-2011 12:21 PM
Stock 02
28
09-24-2006 12:09 PM
stlsparky
11-21-2005 11:02 PM
