twins
twins
Im looking for a set of relatively streetable twins that will support 700hp in a 24v.I will run mach 6 ,smarty and tst or drag comp.Im thinking 35 and Ht3b ,but am a little concerned that they may spool slow.I'm also debating a B1-B2 any suggestions?I wanna run 60-70 psi .I think something along the lines of a big brother is a little overkill for the street am I correct?Any suggestions would be great guys.I would preffer not to use my stock turbo at all for the top.it is junk
I'd do the B1 / B2 combo...........those make for some AWESOME twins!!!! They also spool fairly quick from what I hear.
If you want to wait for a bit, BD is coming out with a new set of twins that's capable of up to 1000HP.......and the twins they have out now are impressive so I can only imagine these will be some real monsters!!!
~Nick
~Nick
I have a 62/14 on top of an S400, which is basically a B1/B2 setup. The 35 on top of a ht3b will be a little small for 700hp. The spool would be pretty good, but the drive pressure would be pretty high at 700hp. Mach 6's and a drag comp, and you will be a little short of 700hp.
Paul
Paul
HX40/B2 with some headwork and cam will make 648/1312 with NO EGT problems...I've seen it done![Wink](https://www.dieseltruckresource.com/forums/images/smilies/wink.gif)
B1/B2 would work too!
I'm going with a PS62/B2 combo on the '98, we'll see how that works![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
Chris
Chris
dodgediesel
17
04-05-2011 11:21 AM
Stock 02
28
09-24-2006 11:09 AM
stlsparky
11-21-2005 10:02 PM
