twin turbos?
I've seen the external wastegate on most twin turbo systems, is this regulated somehow or is it always open just restricted to a certain amount? And if so, to what amount? And if not, what regulates it?
Secondly, by "larger turbo" are you talking about exhaust housing size like using a 12mm vs a 16mm? and/or the compressor volume?
Been interested in this for awhile, but never really knew how to set it up, so figured I'd ask a few more questions to get a good start :-)
50 - 75 % that helps me some and the waste gate dumping more to the second turbo helps alot. the reduction in egt's i was talking about is the 300 or so degrees diff from pre to post turbo readings
It also relieves the restriction that the small charger becomes as boost gets higher.
Justin
dditt0635004x4
13
02-07-2007 12:36 PM
BigBlackBeast05
07-24-2005 09:47 PM
