Twin Turbos
#61
Originally Posted by signature600
I understand![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
Planning on an S300 single somewhere between Super B, and PS62. I would like to have a tiny exhaust housing without a W/G, then use my external gate! I'm strictly towing with this truck now, so spool is most important, with top end being handled by a gate
I might be ~325 when it gets done![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
Chris
![Wink](https://www.dieseltruckresource.com/forums/images/smilies/wink.gif)
Chris
I have a "test" hill that I use to test low rpm air movement (spool). With the Dodgezilla I had on it a year ago, on the test hill at 62mph it would make 10psi and be at 1000* EGT. With the twins on, same mph, it makes the same boost, but only 950* EGT. This is with 3.54 gears. I am extremely pleased with this! The "spool" of the Dodgezilla was quicker, but the amount of low RPM air movement is better with the twins. In other words at a constant 1700 rpm the twins are moving more air then the Dodgezilla was.
Oh yeah in contrast on the same test hill the large single I had last year, would be over 1100*.
Paul
#62
Cool!!
I have a S300 62mm/.7 housing I bought off Ron Allen...I'm gonna bolt that on today and see if it will move enough air and spool OK. Should be great for airflow, but I wonder about the spool of a 62mm wheel in valet (~200hp)
Chris
Chris
#63
Cool!!
Chris
Chris
![Whistling](https://www.dieseltruckresource.com/forums/images/smilies/new1/whistle.gif)
Paul
#64
Actually I just got off the phone with Shane @ Industrial Injection. I think he's talked me into a PS62/.7 Then I'll wastegate it up top to keep thing cool with the switch flipped![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
The Super B I ran started to light around 1200RPM, and was over 40psi by 2000. As long as it's over 30 by 2K, it'll be fine. Biggest thing will be how high EGT's get before it cools off. I should be fine, I hope.
I'm gonna bolt the S300 on tonight, and see how it does. If it works good, I'm selling the HX40, and buying a PS62 to put over the B2 on the other truck![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
I have waaayyy too many turbos
Even I'm getting confused now![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
Chris
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
Chris
#66
And too many friends with trucks they'll fit![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
Right now I have:
HX35/40-14 (Blown Up)
HX40-16W
S300 62/.7
B1-2 (Pretty Well Sold
GT4294
B2
Only 6...there was a time I had over 10, but some were parts.
Chris
Right now I have:
HX40-16W
S300 62/.7
GT4294
B2
Chris
#67
GT4294 (borrowed to a farmer
Chris, his brother Mike and his dad have been calling every day wondering when I'm finished with 'his' B1-2. I'm only ~75 miles into the breakin period, but I'm looking at different options right now. The B1-2 works good until I hit 3rd lockup. It lugs too much at 21k GCVW and jumps to 1200F+ so I bark it real good by backing off the go pedal too fast. I need to try that internal gated GT42 right away.
brandon.
#69
Chris.
Not wanting to get flamed, but I doubt that you will be able to tell the difference between the 62/.7 and the PS62/.7. I was told that a HTT and an II PS are the same. The SPS is different, it has a 6mm larger turbine wheel, and spools a bit slower. It only comes in a .8 exhaust. Both types of 62's seem a bit doggy in twins untill you reach about 20psi total boost. The Dodgezilla starts pulling sooner than that. Even the small (57mm ) S300's seem to behave this way. Boost comes up early, but doesn't seem to bring hp with it. Above 20 or 25psi everything is fine. If you decide to get rid of the 62/.7 let me know.
Ron
Ron
#70
Sorry Ron, not gonna get rid of it![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
One truck will run it...the other will get a PS62/GT42(OR B2 later)![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
I need both...I'm fed up with Holsets blowing up on me
Everytime I put some fuel through one, it takes a dump! The 35/40 I just blew up wasn't my fault though...the back half of the center section BROKE OFF. There is nothing left except the flange holding the exhaust housing on![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
Must have been a bad one![Frown](https://www.dieseltruckresource.com/forums/images/smilies/frown.gif)
Pics on the way![Wink](https://www.dieseltruckresource.com/forums/images/smilies/wink.gif)
Chris
Pics on the way
Chris
#71
chris, sorry bout the blow up, but man am I glad she blew before I made it up there!!
j/k how did you like the S300 with a load on??? & did you run it as a single or with the B2????? I may go ahead & try something along those lines on this 24-v, just want a little more cool air, not goin too big, want a tow friendly charger, just curious, thanks, Dusty
#72
Sorry to rehash such a large post but I have some questions and it looks like you guys have some pretty good experience. I am currently gathering parts to build a twins setup HX 35/40 with an HT3B. Can anyone post a picture of the bracket that supports the 3B? Also, does anyone know where I can get a good price (or have a good used one to sell) for an HT3B? Thanks for the help!
#74
I think he means the bottom turbo support bracket. I don't know how to post pics here, but if you want to pm me an email address, I'll take some pictures of mine and send them to you.
Ron
Ron
dditt0635004x4
13
02-07-2007 12:36 PM
BigBlackBeast05
07-24-2005 09:47 PM
