twin turbo build need help identifying
Hi, I have now a 2500 with the hy35. Back in my turbo buying days I bought these 2 turbo's which are brand new. Would this be ok the build twins?
S300S046 from a john deere 6.8
http://picasaweb.google.be/raffshore/S300#
S400S016 from a mercedes 12L diesel truck
http://picasaweb.google.be/raffshore/S400#
Thanks for the help
Thanks for the help
get a $10 set of calipers or even eyeball it with a ruler to get a guestimate of the compressor and exhaust wheels. The s300 looks big to use as a top turbo. Your hy over the s400 should work though. Might want to do an external wastegate along with the internal.
I cant remember what the s400 is but I know if its a normal s300 is a 57/65/14.
As long as you have a good amount of fueling, the s300/s400 would prob be a real good combo.
Prepair for head studs, fully built trans etc etc though. That couple could make alot of power. Id guess 700 hp and 60 lbs boost? Maybe more if all worked right.
I remember when I bought them that I did do some research and that they came out just fine, but I can't find the correct specs online anymore. I listed them both on ebay, if they sell ok I would go for a complete set. I don't want make more then 600, I want low EGT all the time
What do you mean split? You mean the wall shown in this pic?
http://media.photobucket.com/image/T...s/DSC01007.jpg
I read once why its split like that, but cant seem to remember why.
I think I remember reading that if you cut that wall out, it does something for quicker spool/lower egt slightly. Or something like that.
Hopefully someone else will chime in. But if it came like that new.. Id say its fine.
OldSmokey
06-22-2008 11:20 PM
1974d2004x4
13
10-17-2007 08:47 AM
BigBully
06-28-2006 05:47 PM
