twin turbo alternative??
dont think there is a real substitute for twins at higher HP. You need the airflow that only a large single could provide and the low lag only a small one could manage. Makes sense to compound the two.
For the 350-550hp range you could get a phat shaft 62 or something and probably be pretty happy with it. It will be a tiny tiny bit laggier. You wont grow out of that turbo until you have some serious fueling in place. You can also go with water/meth and extend its use a bit further.
You can use the AFC on a 12v to limit the pre-boost fueling to a haze which works well. But then you lose the ability to smoke out tailgaters. =)
Its all a balancing act.
WOW you got the shaft, unless they are gold plated.
http://www.sourceautomotive.biz/shop...00-107-48.html
http://www.sourceautomotive.biz/shop...bo-108-48.html
JSCumms2000
13
09-24-2008 05:46 PM
1974d2004x4
13
10-17-2007 07:47 AM
VikingDiesel
116
08-02-2006 05:50 PM
MR HYDROSEED
11-15-2005 11:31 PM
BigBlackBeast05
07-24-2005 09:47 PM
