twin problems
twin problems
So i've been screwing around with these twins for a while and i cant get them to spool quickly, im up around 2000 rpm before they get moving. It makes 60+ psi on the top end but by that time i gotta let off cause im doin 100 mph. I started looking at my turbos and i cleaned the plate off on my factory top turbo and its really an H1C...i sound like an idiot i know......on a 95 engine!!...i dont know what size housing it is. Could this be my problem? I disconnected the actuator from the wastegate on the h1c when i built the setup, could the wastegate still be still opening? I'm running an external on the exhaust manifold piped to the bottom turbo.
Sounds like you are on the right track... Need to find out what size housing it has on it.. but since it has a wastegate.. the sizes are limited... Yes the gate could be opening.. or stuck open.. If you take the turbo off.. you and thread the hole and put a plug in it.. or weld it shut.
Try taking the linkage off the actuator, and see if it moves further when it is off... something to try before you take the back of the housing off..
What size housing is on the 3B??
Bryan
Bryan
Yes.. if there is no actuator on the Hc1.. the waste gate will stay open.. so you are basically just driving one side of the Hc1.. (The gate only limits the back 3 cylinders..) Just to try your theory.. just wire the linkage to pull the gate shut..
Good luck..
Bryan
Good luck..
Bryan
If you weld the gate shut, you won't be able to tune. Find a regulated air source and set the wastegate so that the linkage starts to get loose at around 24-26psi. It is also a good idea to drill the hole into the other side so both sides vent a little.
you guys are the freakin best!...I wired that ***** shut and holy cow, thats what i'm talkin about. Like night and day difference, its actually fun to drive now, the turbos are right there on demand at any rpm! I gotta get off my butt and post some pictures up here of this truck, i think you all will like it. thanks again!
here they are! deffinitely wish i took more along the way....1 year project.
http://s37.photobucket.com/albums/e60/pistolpete_059/
heyy! someone else with a cummins-150 now i know im not the only one (: but mine has AC..:P lol yhat may be about to change tho cuz im puttin twins on it right now and i dont know if i can get around that stupid ac box... i alredy melted a hole in the box... oh well it keeps my turbo from overheating too much lol
CrashCade
26
01-12-2009 02:24 PM
1974d2004x4
13
10-17-2007 07:47 AM
BigBlackBeast05
07-24-2005 09:47 PM
