TWIN HELP PLEASE
Old 12-02-2002, 06:48 AM
hellotbone's Avatar
TWIN HELP PLEASE
Ok guys I have an HX40 and I also have the bone stock turbo off my 02 auto can I combine these to make a set of twins for my truck. If so where can I get the parts to match the turbo's togeather. Also what has to be done to the block head anything to make it daily driveable?<br><br>Jamie
Old 12-02-2002, 07:50 AM
banshee's Avatar
Re:TWIN HELP PLEASE
The HX40 isn't large enough to be a worthwhile primary (large turbo). You'll need something about twice the size of your stock HY35 for a twin setup to work correctly. As for the head, an o-ring job with a good head gasket is going to be a necessity.<br><br>John
Old 12-02-2002, 07:53 AM
DTR Advertiser
Don M's Avatar
Re:TWIN HELP PLEASE
It wont work too great Jamie.<br><br>Don~
Old 12-02-2002, 09:35 AM
hellotbone's Avatar
Re:TWIN HELP PLEASE
Thanks guys just curious! I was also wondering what is the max pressure a stock turbo off my truck should make for PSI? Also can I have it modified? To produce more? My hx 40 makes 40 psi but is laggy as hell!
Old 12-02-2002, 10:24 AM
banshee's Avatar
Re:TWIN HELP PLEASE
When it comes to modifying HX35s, HY35s, or HX40s there is only one guy you should consider... Piers. He can mod you stock HY (he calls it the nasty nine), but I think you'll be in a heat issue with your comp box. Instead, I'd send him your 40 for a modification. The difference between a stock HX40 and a Piers modified HX40 is night and day, and his prices are more than reasonable. Also, be sure you're running a 16 cm2 housing.<br><br>John
Old 12-02-2002, 10:47 AM
Hired Gun's Avatar
Re:TWIN HELP PLEASE
I had the same thought Jamie. I have a 99 and the thought of twins are dancing in my head. I hope this thread gets lots of feedback I really want good info. Hey Jamie how about the cluster issue. I pm'd you a while back.
Old 12-02-2002, 12:49 PM
hellotbone's Avatar
Re:TWIN HELP PLEASE
Still lookin for a smashed truck to get a cluster outta hired gun
Old 12-02-2002, 01:37 PM
Hired Gun's Avatar
Re:TWIN HELP PLEASE
I will keep looking also. Thanks for the update.
Old 12-02-2002, 03:05 PM
TxDieselKid's Avatar
Re:TWIN HELP PLEASE
An HX35 with an HX40 has been done before. Now if you don't want to race it, I would try an HY35, and an H2e as their cfm flow rates are idea almost for a compound setup. <br><br>Andrew
Old 12-02-2002, 04:51 PM
Hired Gun's Avatar
Re:TWIN HELP PLEASE
I wondered where my stove pipe went. Looks goodTxdieselkid. 8)
Old 12-02-2002, 07:48 PM
Re:TWIN HELP PLEASE
[quote author=Hired Gun link=board=7;threadid=7762;start=0#74694 date=1038869490]<br>I wondered where my stove pipe went. Looks goodTxdieselkid. 8)<br>[/quote]<br><br>It's not mine, but the gentleman that did it said it was great on the low end, and was a &quot;stump pullers&quot; set up.<br><br>It is an HX35, and an HX40.<br><br>Andrew
Old 12-02-2002, 09:05 PM
Jim Fulmer's Avatar
Re:TWIN HELP PLEASE
I would try an HY35, and an H2e as their cfm flow rates are idea almost for a compound setup.<br><br>This setup would be great to a point, driveability would be outstanding but upper H.P. would be limited to some degree and the H2e is a more exspensive turbo, that's why most of us use HT3B's as they move 1500 CFM or so worth of air and you can by them off the shelf, or you really want them to perform buy one that has been Piersified like mine, believe me it's worth the extra money. An HT3B is not the end all of turbo's, I can think of several after market ones that would work better but there in the 2-3 grand price range.<br><br>Jim
Old 12-02-2002, 09:13 PM
DTR Advertiser
Don M's Avatar
Re:TWIN HELP PLEASE
[quote author=TxDieselKid link=board=7;threadid=7762;start=0#74652 date=1038863157]<br>An HX35 with an HX40 has been done before. Now if you don't want to race it, I would try an HY35, and an H2e as their cfm flow rates are idea almost for a compound setup. <br><br>Andrew<br>[/quote]<br><br>Sorry to disagree, the hY will generally go about 630cfm and the H2E will go about 750. This is nowhere near what you need for twins<br>Don~
Old 12-02-2002, 09:14 PM
DTR Advertiser
Don M's Avatar
Re:TWIN HELP PLEASE
The HT3B will only go 1300cfm at a very high and hot pressure ratio.<br><br>Don~<br>
Old 12-03-2002, 12:41 AM
Re:TWIN HELP PLEASE
[quote author=Don M link=board=7;threadid=7762;start=0#74843 date=1038885209]
Don~
[/quote]
Show me your proof....
We need around 1450 cfm on the first stage to support around 500hp at 3200rpms. The hx 40 tops out at 41psi and 130000 rpm at 800cfm. The h2/hx55 at p/r of 4(41psi) goes to 950cfm at 110000rpm. The next step is the hx 60 is the turbo that goes on the signature 600 cummins, flows up to 1600cfm but the smallest exhaust housing is a 22 wastegated. So it looks like the best combo for the holset is the hx 55 with a 19 wastegated housing.
this is from Adam, someone who I know has spent a great deal of time recearching twins, and who has seen the maps. Not saying you havn't done your homework though, don't get me wrong.
Andrew
Quick Reply: TWIN HELP PLEASE
