turning up p-pump
Old 09-22-2006 | 12:42 PM
90firstgen's Avatar
turning up p-pump
Can somebody point me in the right direction for a how-to thread about turning up the pump on a 97 12 valve? I don't know much about the p-pump since I am a firstgen guy thanks!
Dan
Old 09-22-2006 | 01:59 PM
Baja's Avatar
Go to "Cumminsforum.com", scroll down to "2ed gen tech", open it. Scroll down to "tuning up a p-pump". Read. Lots of info. Good luck.
Old 09-22-2006 | 03:28 PM
TxDiesel007's Avatar
Dan
Several things u can do to a P Pump..
The first thing you should do is get some gauges to monitor your new found fuel...
Second thing that i suggest is to go ahead and change out your fuel plate. You can then add a Governers spring kit to go ahead and widen that normally broad cummins powerband, Next you can bump forward your AFC, and loosen the starwheel a bit for a little more low end fuel..
Fina
DO these things, and u will feel a noticable difference over stock.. Feel free to PM me if you have anymore questions..
Rick
j_stickers
09-13-2004 08:23 AM
racermatt2606
08-27-2004 12:04 PM
mitch@jc'sCTD
08-19-2004 06:42 AM
Stomp
05-01-2004 01:25 PM
thumbs
06-13-2003 09:34 AM
Quick Reply: turning up p-pump
