Turbo Timer Question
I hope someone can help me out here. I want to get a turbo timer (TT) for my 96 CTD. When I go to ebay, you can get them from about $30+ but if you put diesel in with the search they go to $150+ do I need one made for the diesel? The way I understand it works is that when you turn the key off the TT maintains 12Volts to the fuel shut-off. Now I know that there are two relays in the system the one that opens the shut-off takes alot of amps to work but the one that holds it open does not and I think thats the one that the TT would work with. So I'm thinking you don't have spend the $150 for the TT on the diesel. If I am wrong aout this will someone set me straight.
you need one that will keep the fuel pump runnig and some of the elec also.
mine even keeps the a/c running for whatever amt of time you pick when you get out of the truck.
i cant remeber what the name is but it does waaaayy more than just operate the fuel sel. ill let ya know if i get the name.
i got it. turbo lifesaver
06RAMCTD
11-06-2009 12:35 PM
CTDPower11
01-23-2007 10:29 AM
TripleBquad
13
11-20-2006 03:59 PM
turbo_2500
12-30-2005 07:15 AM
