Turbo Timer Problems
I did a search for this but couldn't find anything. I installed my Edge last weekend and it has worked flawlessly power wise. I still haven't gotten the turbo timer to work. I checked all connections including the wire running to the fuse, but still no timer. Should I just ask Edge for a new Programer. Sometimes I don't have time to wait in the truck for 5 minutes to shut it off, the timer would be nice. THanks guys.
Watch your pyro. Below 300 or 350, shut it off. You don't need to sit for 5 minutes every time.
As for the actual problem, I'd say give Edge a call. Or check their site, they may have a troubleshooting area.
1 Post
Check to see what your shutdown temp is set to. Maybe your egt is already cooler that what the shutdown is set to. You'll be safe setting it at 300*. If this isn't the problem I would call Edge.
I have the same problem. Sometimes, the truck won't shut off at all. I disabled the timer on the monitor and i plan to call edge soon.
06RAMCTD
11-06-2009 11:35 AM
CTDPower11
01-23-2007 09:29 AM
TripleBquad
13
11-20-2006 02:59 PM
acook
07-27-2006 06:48 PM
