View Poll Results: Whats your Turbo Timer shutdown EGT setting at?
Lower
4.35%
280's
4.35%
290's
0
0%
300's
34.78%
310's
0
0%
320's
17.39%
330's
4.35%
340's
4.35%
350's
17.39%
Higher
13.04%
Voters: 23. You may not vote on this poll
Turbo Timer EGT Setting?
Old 03-27-2007 | 11:47 AM
4RnrRick's Avatar
Whats a good EGT to shut down at? Right now I have mine set at 330 degrees. After the motor is off, it appears with Heat Soak - the temp will climb back up to 390 before it starts decreasing again....Is that Okay? My gut feeling says I should lower it some more.
Old 03-27-2007 | 01:29 PM
b4wheeler's Avatar
Personally I think 350 is fine.
My truck will sit at almost 400 degrees just idling. I don't think mine would ever shut off if I had it set much lower than that.
Old 03-27-2007 | 01:52 PM
4RnrRick's Avatar
Thats another problem I see with asking a question like this.... it seems that Pyro's can vary quite a bit. My old gauge mount pyro on my 92 dodge would change 100 or so degrees depending if the lights were on or not....
Old 03-27-2007 | 08:56 PM
GPSflyer's Avatar
My 01 Auto with stock turbo cools down to 300 in about 2-3 minutes. Pyro is pre turbo. I keep my turbo timer set at 300.
Every truck is different though, you'll have to see how yours reacts.
Old 03-27-2007 | 09:56 PM
CSAGrey1's Avatar
It takes for flipping ever for mine to get down to 300 even in below freezing temps. I don't have a turbo timer but I shut it down when it is below 350. Most of what I have read recommends 300.
Old 03-27-2007 | 10:14 PM
Jordan5687's Avatar
I have mine set to 300. Usually takes about a minute or 2. EGT probe is pre-turbo.
Old 03-28-2007 | 10:57 AM
4RnrRick's Avatar
I did my heat soak test again and it only increased by 30 degree this time after the vehicle shut it self off.....
bump for others to vote on...
rocksride
12-23-2013 02:03 PM
06RAMCTD
11-06-2009 12:35 PM
CTDPower11
01-23-2007 10:29 AM
TripleBquad
13
11-20-2006 03:59 PM
