Turbo Recommendation
Hey guys,
I want a single turbo that has exceptionally fast spoolup, like my stock hy-35 or better. I have an edge comp box and will add whichever injectors are needed. I don't tow and I don't haul very much. I just drive it on 5X5. All thoughts are welcome. Scott
From: Drive till ya hit a Polar Bear, then go back 50 miles
You're not going to find a turbo that spools faster than your HY35, while still providing more airflow or turbine flow. The KSB1-2 is, in my opinion, the fastest spooling charger that can support 375-400 HP. KSB1-2, Comp, Mach 1.5s is good for 380 HP. You will still see some warm temps (long hard pulls will see 1400 - 1500), but spoolup is about the same as an HX35, which is to say a couple hundred RPM slower than you're seeing right now.
Rod
Rod
Scott
Agree with Rod!
I had bigger injectors before I added KSB1-2, so I noticed a slightly slower spool up - but nowhere near the increased lag I expected. Took all of 1 day before I didn't even notice the difference - and my boost level went from 34 psi to 48 psi.
If you added slightly bigger injectors (like the 1.5's) and the KSB1-2 at the same time, you might not see any slower spool up; but no turbo on a CTD is faster (or smaller) than the stock HY-35.
RJ
RJ
Ok, well that kills that idea. I have seen some discussions about smaller sets of twins, but nothing has been mentioned definitively about the possibility. Is there a twin setup, in theory, that could use my hy-35 and a bigger primary turbo? I want a setup that is really quick light to light. And I figure having my edge comp reworked to be an edge comp drag will help a bit on the top end.
Twins with HY-35 have not proven themselves as yet. many have tried to make it work with little luck.
Also, I believe all twins spool slightly slower than their smallest turbo! It's physics and the nature of the beast!
RJ
RJ
MrSuzuki
13
07-29-2007 08:29 PM
MrSuzuki
07-29-2007 07:30 PM
CButler610
10-14-2006 07:50 PM
