Turbo questions
Turbo questions
Can someone tell me:
- what turbo came stock on my truck?
- is there any upgrade, housing etc, that will give me some noticeable improvement that wont cost an arm and a leg?
I do tow a trailer of 10m plus, so I could use a quicker spool up. FASS system is coming soon...
A 2000 truck would still be a Holset HX-35 (12cm exhaust housing). The HY-35 (9cm exhaust housing) started on the SO (auto, 5-speed) trucks in 2001.
EDIT: correction, POURINDIESEL is correct, brainlapse. Automatic, SO trucks are the only ones with 9cm HY-35 turbos.
A Dodgezilla, or any of the hybrid turbos with an HX-40 compressor side and HX-35 14cm exhaust side will bolt right in and give a lot more flow.
Dodgezilla
What are your EGT, boost, etc running now?
I'm sure someone here more knowledgable than me can stear you right if you need a turbo upgrade.
Dodgezilla
Clucker
22
09-24-2009 09:34 PM
pistazie
ABDTR #5
04-30-2009 08:16 AM
GR40RCapri
10-30-2007 09:37 AM
gman07
04-15-2006 08:32 PM
