Turbo questions
Turbo questions
I have 02 with a TST Comp stacked with a smarty right now. I wanna get a new turbo but not sure which one to go with. I wanna add 90hp injectors in the furture but really dont wanna have to upgrade the turbo again. I know I will have sacrafice spool up some. I also have 40 inch tires with 3.55 gears so EGTs are a little higher than stock tires.
Is there any advantage to a stainless steel turbo cause I found this one.
http://cgi.ebay.com/ebaymotors/NEW-S...QQcmdZViewItem
Strictly Bling and too small, IMO!
You will probably want one of the S300 variations with a 64 compresssor housing. Your biggest decision will be turbine housing size. With your tires I would stay with a smaller 12-13 cm equivalent (for spoolup) and live with some EGT problems at WOT.... unless playing hard is your primary concern.
RJ
RJ
RJ
RJ
I'm guessing the 71mm wheel that both II and HTT use. I just hear people call it 80 and not sure why.
Clucker
22
09-24-2009 10:34 PM
pistazie
ABDTR #5
04-30-2009 09:16 AM
GR40RCapri
10-30-2007 10:37 AM
gman07
04-15-2006 09:32 PM
