Turbo Needed?
Old 03-07-2008 | 09:35 PM
jprice's Avatar
Turbo Needed?
Hey, put the Adrenaline on my truck and it is awesome but im kinda worried. When ever i cram in it i can hit 48 psi boost according to the pod. Is this accurate? My stock hx 35 has the wastegate blocked, im gonna put the stock elbow back in and see what happens. Do you think i need a turbo? What kind? Which ones are safe on a stock head gasket and head bolts?
Old 03-07-2008 | 10:07 PM
Mike D's Avatar
Hmm... blocked wategate, wire tap box and 150 HP sticks. You want to know if 48 psi of boost is accurate? Yeah, I think it's accurate.
Old 03-07-2008 | 10:10 PM
jprice's Avatar
How much pressure will a stock turbo hold?
Old 03-07-2008 | 10:51 PM
Bjans's Avatar
your right there! is it hot as a firecracker?
Old 03-07-2008 | 11:00 PM
jprice's Avatar
Its runnin a little warm but i dont like to stay in it too long. U like ur sps 62? Thats what i been lookin at.
Old 03-07-2008 | 11:08 PM
rattlerbob5.9's Avatar
Run it through all the gears with your foot and pedal on the firewall and let us know or put the fuse (elbow) back in the circuit before it blows
Old 03-07-2008 | 11:15 PM
jprice's Avatar
Well, i guess we got a bunch a smartasses 2 nite! Thanx 4 the help!
Old 03-07-2008 | 11:18 PM
Bjans's Avatar
I like the super 62 it rocks pretty good. i can heat it up with my setup but its pretty sweet
Old 03-07-2008 | 11:20 PM
jprice's Avatar
u got ur head studded, how much boost you push BJANS?
Old 03-07-2008 | 11:24 PM
Bjans's Avatar
No studs yet! thats my next mod. I can bury my 60lb boost guage with what i have!
Old 03-07-2008 | 11:32 PM
If you want that hx-35 to run for a while yet put the elbow back in and regulate the max boost down around 35 psi much past that you will just be pushing hot air or run it like it is and order a new turbo NOW!!!!!!
Old 03-07-2008 | 11:38 PM
1BAD4X4's Avatar
Yeah it doesn't sound like you need a new turbo nessecarily... atleast not yet. I'd get the studs and might as well take care of the head while your in there. Thats if money permits that is. Once you know that the head gasket can take more, then a new turbo for even more boost.
Old 03-07-2008 | 11:42 PM
jprice's Avatar
35psi. Thats what i needed to know. That sucks. Ill b orderin one tomorrow!
Old 03-07-2008 | 11:51 PM
jprice's Avatar
Yea, ive got the studs, i was waitin on the turbo and do it all at once and step it all up a notch. Thanx
Ada381
02-10-2008 08:58 AM
IH8MYCAT
03-23-2005 02:17 AM
wrk24wheel
09-24-2004 12:15 AM
tcr
05-10-2004 09:16 PM
2broke2smoke
45
01-26-2004 04:59 PM
