Turbo money has arrived............
Old 02-23-2008 | 11:25 PM
  #46
98.5Hotrod's Avatar
yes they change the turbine housing to the hx-40 style.
Old 02-23-2008 | 11:45 PM
  #47
Mike Holmen's Avatar
The Guru
They must have adjusted the turbine blade tip to housing clearace. I just tried mine and its to tight without machining it out some. Are they using the same turbine wheel as well. Interesting stuff. Anybody have pictures?
Old 06-04-2008 | 02:05 PM
  #48
soulezoo's Avatar
DTR 1st Sergeant
What do you guys think about using a larger turbine housing on the secondary turbo vs tighter one. Obviously your intial spool-up will slow, but your primary might lite better and making more mid and top end power. Lower egt's. I'm thinking about trying two different HX-40's (six blade and a eight blade impeller) and two different turbine housings. What do you guys think, this is just dyno day stuff/drag racing or there any value in this. I have five HX-40, everyone is slightly different. Two have coolant jackets bearing housing off a gen set T04 8.3L cummins. I just changed the turbine housing off my PDR Hx-40, I have something pretty cool.. I also have 14cm turbine housing and a 16cm turbine housing for the T03.
I resurrected this thread just to answer the EH housing question... real world results in... the primary lites so fast-- even before the wastegate opens-- that the larger EH is not necessary unless you are throwing a ton of fuel that makes it necessary for the sake of lowering drive pressure.
To put it in relative terms, comparing to my old 35/3b set up (wastegate on the hx35 set at 24psi), the bottom BB turbo lites twice as fast (no exaggeration here-- real deal) as the BHT3B to 25psi and this happens before the top wastegate (set at 40psi) opens. This is with the "smaller" EH on top. What I have found is in the new setup the bottom turbo participates a lot sooner and shares more of the load throughout the psi range than my old setup.
Old 06-05-2008 | 12:13 PM
  #49
soulezoo's Avatar
DTR 1st Sergeant
I posted this back in the "twin turbo" thread as well so this is a duplicate... but for future "searchers" the answer to the question above is that the bottom turbo goes from 2 psi to 27-30psi in the time it takes me to say "one-thousand-one"... or about one second.
spooled142
03-25-2009 01:32 AM
moss2904
19
02-23-2003 07:16 PM
Nuttymopar
02-14-2003 10:45 PM
JayDee
11-01-2002 11:48 AM
Hunter
10-28-2002 09:44 PM
