turbo kits
Old 12-29-2007 | 10:44 PM
coonhunter723's Avatar
turbo kits
do they make a twin turbo kit witout the turbos
Old 12-29-2007 | 11:17 PM
kas83's Avatar
sourceautomotive.biz can hook you up with all the piping/hardware and such to put together a set of twins.
Old 03-10-2011 | 10:07 PM
amandrew325's Avatar
I am debating on getting the BD twin turbo kit for my truck and I have a few questions.
Anyways, I would like to get some specs on the turbos, etc. What turbos are included and what are the specs on each turbo?
Also, how will this kit be for a daily driver, sled pulling, and some towing. Does it keep the EGT's in check?
How much boost is this twin set up capable of?
Also, I have read before that anything over 550hp on these twins is no good. I heard 550hp and below is what these twins are for, but then it says its capable of 700 + hp, so which is true? I'd imagine what is on the site, but you never know, just would like an honest opinion on what kind of HP rating you can make out these and still have them in there efficiency range.
Thanks...
________________________
"If everything comes your way, you are in the wrong lane"
Superchips Cortex Tune, AMSOIL lubed, AEM Brute Force CAI, Turbo Kits, Magnaflow Cat-back Dual exit Side-Swept Exhaust with gorgeous Stainless Steel Double-wall ten inch tips, 2" PRG leveling kit, 275/60/R20 Cooper Zeon LTZ tires on MB Predator wheels. 4 piece T-Rex vertical billet grill, chrome foglight inserts, chrome tailgate cover, tinted windows
Old 03-10-2011 | 11:38 PM
dieselboy59's Avatar
Hi I just installed the bd towing twins .nice set up .spools the same as stock at low end.I am running 100 h.p injectors and j/with/a.it will run 56 psi of boost.and egt will not go above 1100 pre turbo.I do not know how much boost can be run with them.it is a great kit just bolt together.
TheNeckasaurus
10-13-2010 09:16 PM
customizedcreat
05-19-2010 02:44 PM
LLoTuner
04-10-2008 12:28 AM
Igor
08-06-2007 10:39 AM
deputyski
04-03-2005 10:01 PM
