turbo, injectors, studs??
im wanting to add jammer 5s and upgrade my comp to drag. wat turbo would be good? i here good things bout hx40 and super b.. wats the s300 like? of course i need a clutch and air dog before that. also, wen do i need head studs and wat exacly do they do??? thanks
I have 150's and I run a II ps64/14. if I were to do it again I would get the sps64 but with what I have now I can get around 50psi of boost so I know that I will need studs and o-ring to so if I were you I would be prepared to get them also or do like I do and be careful of your boost. The studs are stronger than stock bolts and can be torqued down tighter so that the head gasket seals better with the higher boost pressures.
Dont go by how much they cost. Your this deep into doing some bombing that money really shouldnt be the issue. If you want it get it....dont go the cheep route or youll pay in the long run.
One step at a time buddy, get the fuel system done. A fuel pump and lines are an easy afternoon job. Then find a clutch. Recommendations will vary depending on what you want to do with the truck and the manners you want. Spool monster or do you want it to eat up top?
hawaiianbro
12-29-2012 10:26 AM
77machomopar
11-30-2009 11:55 PM
Hillbilly Delux
02-07-2008 12:21 PM
RyeThomas
09-29-2006 11:17 PM
