Which turbo? Which Injectors? Which module?
The Guru
Bradleysram, I was just talking to a friend regarding that combo. The HX-55, isn't big enough to justify doing it as twins. Decent spool-up, just no strong mid to top end power. BTH-3B works nice so does the S475, if price is important. I try to keep the primary to under $700, so I'm choosey. The S480 is around $1200 to $1300 and the 4508R, is around $2k, so there a few choices.
From what ive been able to find out the HE341 is a 56/60/9 and would be used in the top and the HX55 is a 65/77(i think cant read my notes)/22. does this sound right
The Guru
Something thats cheap, has a inducer at least 70+mm and rated around 100lbs/min. Keep the A/R on the turbine reasonable, the S475 is 1.32, which is abit big but isn't too big. A K-31 turbo has a tighter a/r and nearly the same compressor performance.
Common primary twins turbo are BTH-3B (26cm), S475 (1.32), or K-31 (more money).
SilverRam3500
05-16-2007 09:37 AM
RAM123
11-02-2006 07:52 AM
