Turbo & injector suggestions for towing
My sig pretty much sums up my current mods. Would definately like to get more out of her and I'm thinking a set of injectors is the way to go. I realize that I'm already pushing my stock hy-35 to it's limits and in order to add more fuel, I'll most likely need to upgrade to a different turbo. I typically tow around 10,000 lbs, occasionally lighter, occasionally heavier. What turbo/injector combo(s) will net me another 100-150 hp yet still keep the EGT's in check while towing?
throw in a set of rv275's they are dirt cheap and although in the seat of your pants you wont feel a whole heck of extra power, when you tow with them you will surely notice it. Plus you can keep the stock turbo with that set up
275's give a little bump! If budget allows...Mach 1.6's are a real smile maker! Low smoke (for the HP) and designed for towing.
On turbos...your choice! At least a hybrid HX-35/14, like the Dodgezilla! One step up from there, IMHO, is the Phat Shaft 62/14! But it's a big step up, and worth doing if you go with anything bigger than 275 injectors.
JMO as always!
RJ
JMO as always!
RJ
Just saw where your actually looking for 100-150 HP. PS62 and Mach 1.6's will dyno maybe 120 hp!
And if that's as far as you plan on going, HP wise, I would get the PS62/12, instead of the 14 cm2 turbine housing, if available!
RJ
RJ
Not laggy, in my opinion....because of your 6 speed. Towing over 7000# (+/-) with an Automatic is a "whole nother country". Much harder to keep the rpm's up (with the auto) and there is a hugh gap between 3rd and Overdrive.
But if you are not reving up to 2500+ rpm before each shift...you would have to get use to something like that for good air....a scenario you already may have expirienced with your new injectors??
I see some guys shift like that all the time while others get in the habit of shifting much lower, around 2000 rpm. Really depends on your driving stye...as I see it.
RJ
RJ
jmd4993
07-15-2013 11:02 AM
mattmanj2001
05-20-2010 08:12 PM
roadranger
13
11-29-2006 06:17 PM
