Turbo housing
Old 02-05-2008 | 03:48 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Turbo housing and internal difference
I was reading a section on the internet saying there are slight difference in the HX35 stock turbo used on the '94 to 2001 model year.I thought all HX35 are the same from factory?Are there any difference from a HX35 from '94 compared to a 2001 HX35 beside wastgate location?
Old 02-05-2008 | 06:29 PM
HOHN's Avatar
The 95- to early 1998 turbos had 54mm inducer wheels with a 83mm exducer size that was 8 blades.
Later turbos (late '98 to early '04) have 54mm inducers with 78mm exducers and 7-blade wheels.
That is, if you trust the info on HTT's website.
JH
Old 02-05-2008 | 06:31 PM
kxhonda's Avatar
I've heard some have a 54mm compressor wheel and others have a 56mm wheel. My 99 had a 54mm compressor wheel.
Old 02-05-2008 | 06:33 PM
HOHN's Avatar
I've heard that, too-- but the HTT site doesn't mention that 56mm wheel.
I'd like to know which trucks had it, if any.
jh
Old 02-05-2008 | 06:42 PM
thewished's Avatar
94's and 95's came stock with WH1C's not hx35's.
Old 02-06-2008 | 01:10 AM
Tate's Avatar
I thought it was just the 94s that came with the WH1C.
Old 02-06-2008 | 01:23 AM
thewished's Avatar
My 95 has a WH1C
Old 02-06-2008 | 01:32 AM
4doogie's Avatar
ok so i have a 94 wuts the deal with that turbo? any good?
Old 02-06-2008 | 04:35 AM
LanceD's Avatar
my 95 has an HX35
Old 02-06-2008 | 07:01 AM
Fishin2Deep4U's Avatar
There were a few different HX35 wheels used. I know the CA models had a different wheel. I would suspect high altitude models may have had the smaller wheel as well. But just a guess.
Dave
Old 02-06-2008 | 12:52 PM
So did I do a downgrade on my truck?.My 95 had a HX35.I installed a replacement HX35 from a 2000 dodge.
Old 02-06-2008 | 03:45 PM
HOHN's Avatar
Originally Posted by LanceD
my 95 has an HX35
It seems to be another one of those "early/late" Chrysler midyear changes, like the switch to 24V in '98, the rear discs in '01, and CAD delete in '02, etc.
"Early" 95s should have the wh1c, and the "late" 95s should have the HX35.
Check the MDH sticker in your door jamb.
Also, keep in mind they supply overlap, too--- they are going to use what they have in stock before the switch over. So not all "late" 95s would necessarily have an HX35.
jmo
ajbirken
09-06-2006 01:11 AM
95black2615
07-21-2005 10:06 PM
j
01-09-2004 09:19 AM
HOHN
12-07-2003 03:07 PM
dieselinveins
11-06-2002 10:17 PM
