turbo Hot Housing?
turbo Hot Housing?
I'm changing the turbo out replacing it with a PDR HX35 my question is should I change the housing to 14cm or a 16 cm or just leave the housing at 12cm? I will be running a 10 plate with 215 injectors and a 3k kit. I haul a lot of weight so I don't want over fuel it to bad and i don't want much turbo lag.
What do you guy's think?
I would also vote for the 14cm with your mods.. That would help out alot in the top end fueling and EGT. With the stock 12cm, the fuel load over 2700 RPM makes the EGTS climb pretty fast. That housing is a good compromise.
J-eh
J-eh
Strjock81
16
12-12-2007 09:53 AM
duallydave
08-07-2005 09:38 PM
HOHN
12-07-2003 02:07 PM
