turbo hose
Old 12-26-2012 | 10:59 AM
jim555's Avatar
turbo hose
I think I should be getting bout 30 pounds of boost(edge EZ w/ boost elbow from kit installed). I am only getting 20. I have been told i am leaking boost from the hoses. I plan to get new hoses (from DSM piping). any comments(should i use new clamps etc.)
Old 12-26-2012 | 12:28 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Is the truck blowing alot of black smoke??That is one indication of bad boost..You should be getting 30 PSI plus....Check your boost hoses...As for clamps,it's your call...I still have the orginals,but if you want to replace them,they are not very expensive..(priness auto)
Also check your intercooler for leaks...One fellow here had a small hole in his cooler..
Old 12-26-2012 | 01:52 PM
infidel's Avatar
Cheap hairspray sprayed on the boots before installing helps keep them from blowing off but still easy to remove later if needed.
Then you can reuse your old clamps.
dzlfarmboy
10-18-2006 06:27 AM
whatdieseltoget
09-15-2005 01:19 PM
george7941
08-10-2005 08:06 PM
awells
09-30-2003 01:34 PM
13
04-19-2003 05:12 PM
