Turbo help needed......... Please...
Old 03-23-2005 | 12:34 AM
IH8MYCAT's Avatar
I've noticed that my turbo boost gauge reads 15 psi when just cruising at 70mph on level ground, not hooked up to a trailer, or anything.
I was told that it should only read about 7 psi............. Is this true ??
If so what could be the problem, or cause of this, and would this explain poor fuel ecomomy too ??
What can I do to fix it ?? and YES, I only have the factory elbow on the turbo too.
Thanks...
Old 03-23-2005 | 01:13 AM
1320's Avatar
the real question is drag....and how level? A slight grade (not perseptable by eye) can raise my boost to 15. Ussually I pull 10 psi or so......sometimes 15k sometimes 7.....with slight changes in the road. All of witch I would call level but is NOT. If you pull 15 all the time(no head wind)......I d look at the brakes......which could cause a milaege loss. The 15 psi is not IMO.
Pulling my 50 ft vintage, I run 15-20 on level looking ground. egts about 1100.
pulls 54psi on the hills......
Old 03-23-2005 | 02:17 AM
BigBlue's Avatar
I agree on the ground part. I see between 7-10 on perfectly flat ground and 15-20 on seemingly flat ground. If yours is doing it all the time then something is dragging and causing it to read that. It could possibly be a bad gauge as well.
DieselSmith
07-02-2009 07:06 PM
Jordan5687
35
10-02-2007 07:12 PM
SuperiorRam
03-15-2007 04:10 AM
royta
08-30-2004 01:41 PM
canucktrucks
03-13-2004 09:28 AM
