turbo help
how much you want to spend? $500, $1200, $1500, or $3000.
How much HP do you want to use?
How much HP do you want to dyno?
How much HP do you want to tow with?
After answering all of those questions, members here will be able to make an excellent recommendation.
somewhere around $1200- 1500, also have laser cut delivery valves which i havent installed yet, want around 450-500 hp, i dont do alot of towing..Have a 3 6 fuel plate as well which insnt installed as of yet..any suggestions?
I love my Industrial Injection Silver64 (64/73/14)
Its probably a little big for you truck and fueling.
I know of a guy who used to be on here that did 535hp with a II SPS62. Great EGTs, can tow and get you the HP you want.
If I were you, stay away from the HTT 62/65/14 or II Phat Shaft series. Make sure you get a 71mm turbine wheel, youll have room to grow.
You will run out of turbo FAST. Dont ask how I know.
Question..i am having a spare p -pump built at this time, it will have 3200 gov kit, laser cut delivery valves, etc..it will give me 325hp on a stock truck..now i know i will prob have egt issues....which turbo would you recommend if i would like to dyno around 450 - 500hp....i know i will need a clutch, prob larger injectors..with that said which Turbo will give me the least problems..i dont tow much ,just want to have the power and torque on tap...any help would be appreciated
CumminsRedneck
07-06-2013 04:20 PM
Haulin_in_Dixie
07-21-2003 12:14 PM
redram
12-10-2002 10:54 AM
