Which Turbo to get?
Which Turbo to get?
I've finally figured out what power options I want. But now I'm trying to figure out what to do with my turbo.The stock HX35 just won't be able to keep up once I have all the power upgrades installed. Here what I've have and/or soon to be installed/altered:
#10 (custom - a little taken off the top for more high rpm power) full forward
3GSK
DDP stage 3
Snow water/meth stage 2 w/220psi pump (using both 625ml nozzles)
16° timing
AFC housing full forward w/light spring (no tension)
ARP head studs
Lost muffler & gutted cat
60Lbs exhaust springs
Truck is used as a daily drive. I accationaly tow a 6K lb trailer.
Piers has mentioned that a twin setup with my stock HX35 on top and a HT3B on the bottom would work nice for me. But I'm thinking I can get the job done with a single. I've been looking at the Phat Shaft 62.
How do you think my stock HX35 would do with a 14cm housing on it?
Any suggestion/Comments would be appreciated.
Also any idea on what HP this will give me?
3GSK
DDP stage 3
16° timing
ARP head studs
Bradleysram
19
05-12-2009 09:36 AM
Badd Dogg Guy19
29
10-18-2006 08:44 AM
blackdiesel
09-05-2005 01:17 PM
