turbo elbow
Old 03-01-2007 | 11:46 AM
RowJ's Avatar
Originally Posted by green machine
... also what is the cel
Check Engine Light? Not sure where you saw this?
If only adding small amt of hp in the future (up to 325+/-), you can just block off the wastegate tube completely and still not worry about over boosting.
Elbow only serves a purpose if you can over rev the compressor.... say more than 35 psi boost.
RJ
Old 03-01-2007 | 12:19 PM
green machine's Avatar
is there anything i can tweak on my afc to get more fuel or slide my fuel plate back. If so how do i do either of these if you would be so kind.
Old 03-01-2007 | 12:24 PM
Forgot to ask would it be more beneficial to block the wastegate, if so what does that exactly do and how do you do it
Old 03-01-2007 | 12:38 PM
wcbcruzer's Avatar
Check out the installation instructions on www.tstproducts.com on the fuel plates. You can slide your fuel plate forward to gain a little more hp. Blocking the wastegate won't hurt. Like mentioned above, as long as you keep it under 35 psi. But I don't even think you can reach that level with a stock fuel plate that's slid forward. Blocking it and boost elbow is practically the same thing.
Old 03-01-2007 | 02:12 PM
RowJ's Avatar
.. would it be more beneficial to block the wastegate, if so what does that exactly do and how do you do it
Not more beneficial...just easier than tapping, etc.. Keeps the wastegate from activating and prevents limits on turbo boost. May prevent wastegate from opening partially, too early...as some high mileage WG's do.
One easy way is to unscrew current elbow at turbo (pictured above) and replace with a $.50 pipe plug. Disconnect hose at wastegate and store all for possible need later...as you add fuel and get over 35 psi.
If unfamiliar with wastegate operation...and turbos in general, good read Here
RJ
Old 03-01-2007 | 02:29 PM
thanks rjohnson for the great turbo resource site
Old 03-01-2007 | 02:34 PM
RowJ's Avatar
... would i need to do some mods to dump more fuel or will it give me more pounds of boost stock
Yup!
Do a search but this thread (free Mods) will get you started...
https://www.dieseltruckresource.com/...ree+horsepower
Old 03-01-2007 | 06:42 PM
wcbcruzer's Avatar
I just used the screw that came out of the intake manifold when I hooked up a boost gauge.
dodgediesel
14
12-14-2006 10:54 AM
andyr354
12-15-2004 06:40 PM
kevlar
07-10-2004 06:55 PM
Matt
12-12-2002 10:58 AM
