turbo elbow
Old 02-26-2007 | 05:19 PM
green machine's Avatar
Question turbo elbow
does anybody know about the turbo orifice that allows you to control boost. Thinking about installing it but not sure of the pros and cons. Thanks
Old 02-26-2007 | 05:37 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
I'm running one and i think it operates great. My HX35 would only spool up to about 26 lbs. After I installed the boost elbow, it'll get up to 35 lbs.
Old 02-26-2007 | 07:50 PM
wcbcruzer's Avatar
There's no downside that I see. You can make one. Just take your current brass elbow and drill and tap it to fit an allen screw. Once you get it set, I'd seal the screw with something so there's no air leakes; but sealing is probably not even important.
Old 02-26-2007 | 07:54 PM
JPR Ram's Avatar
i agree, sealing the screw isn't necessary. the bd diesel elbow i purchased has a very small orfice that runs from the side into the threads of the set screw. a relief orfice?????? so if the set screw leaks a little????? oh well??????
Old 02-26-2007 | 08:13 PM
Jordan5687's Avatar
So in more detail how can you make one yourself? I'm pretty interested in it.
Old 02-26-2007 | 08:22 PM
JPR Ram's Avatar
personally, i wouldn't take the time to built one. new, they only cost about $25. And, jordan5687, if you get that bd lift pump at the same, the shipping will be a moot piont...... IMHO
Old 02-26-2007 | 08:24 PM
wcbcruzer's Avatar
Just take your current elbow and drill it, then thread it. I forgot what size bit and tap I used, but it doesn't really matter. Just whatever fits, try to stick to standard sizes so it's easy to find a screw for it later. Then go to the hardware store and find an allen screw that fits.
Should look something like this when finished:
They also have them on ebay:
http://cgi.ebay.com/ebaymotors/DODGE...spagenameZWDVW
Old 02-26-2007 | 08:27 PM
JPR Ram's Avatar
Just take your current elboe and drill it, then tap it. I forgot what size bit and tap I used, but it doesn't really matter. Just whatever fits, try to stick to standard sizes so it's easy to find a screw for it later. Then go to the hardware store and find an allen screw that fits.
the stock elbow on mine didn't have an area to drill. it was more of a brass pipe curved with a little casting squared off for wrench use. it was just easier to buy a new one......
Old 02-26-2007 | 08:34 PM
wcbcruzer's Avatar
Oh really? Do I just have a weird stock elbow? Mine looks just like the one in the picture, minus all the teeth on the hose barb.
Old 02-26-2007 | 08:39 PM
Jordan5687's Avatar
JPR Ram, what is it called. I looked on thier site and can't find it. Thanks
Old 02-27-2007 | 06:25 PM
can anybody tell me what type of sealant to use on the allen screw. Locktite?
Old 02-27-2007 | 07:20 PM
wcbcruzer's Avatar
Naw, don't worry about sealant. If you really want, I'd use blue locktite or some Permatex anti-seize.
Old 02-27-2007 | 07:40 PM
JPR Ram's Avatar
It's called a BD Performance Elbow Orfice. I didn't find it listed on their site either. I did find it on their price sheet. While on their site go to the ram section, then look at the lower right area of the page. You'kll see the price sheets. It's a pdf. file.......
Old 03-01-2007 | 01:35 AM
I had another question about making the boost elbow. say i drilled tapped and put a allen screw in would i need to do some mods to dump more fuel or will it give me more pounds of boost stock also what is the cel
Old 03-01-2007 | 01:42 AM
wcbcruzer's Avatar
You will need more fuel. Without more fuel your boost levels won't change at all. I know from experience.
