Turbo, DV, GSK Recommendation Needed??
Hi to all,
Been some time since I have posted. My original mods have become a little boring for me now. Want to take the next step. Looking at three areas of modification...1) Turbo 2) Delivery valves 3) Governor kit
1) Without a doubt, I don't have enough Turbo. I am pushing 30-35 psi with my stock turbo, and I have a lot more room to move my plate, but all I will do is pour more smoke out the back. So, some time ago, I had decided a B-1 was the way to go, but I have been away for a while, and don't know if things have changed...any recommendations?
2) Stock DV's are probably in need of change also...what would make for a good setup, to avoid having to change anything I have already done, and work well with the recommended turbo?
3) I would like to go to a 3K kit...or shim it...as everything I had read before, says it makes for a whole new feel of the truck...your thoughts?
Looking to take my current setup to the next level!
Having a GSK is worth it's weight in gold. Since you have the smaller pump (175) I think the 4K would be good for you. Some good DV's would be 191's. They would add some power and not a whole lot of heat like laser cuts. A good turbo would be a 62. It might still get a little hot, but the drivability of it would be a lot better than a big single.
Stock dv's, a htt 62/14 and a 3gsk will wake her up...If your H3LL bent on dv's be ready to deal with the miss associated with our ip's...I run L/c dv's (real hot and smoke worse then 4 mack trucks taking off at a redlight)...Try 191's but you may just go right back to the stock dv's
MrSuzuki
13
07-29-2007 07:29 PM
EricE
09-28-2006 06:54 PM
EricE
09-27-2006 02:28 PM
Got Smoke?
10-26-2004 03:57 PM
