Turbo Drain Hose
Old 10-17-2006 | 08:24 PM
dzlfarmboy's Avatar
Question Turbo Drain Hose
Anyone that has needed to modify their turbo drain for wastegate clearence on aftermarket turbos, maybe cut it some and replace with hose. What kind of good hose did you use that will withstain the heat and the oil and not break down. Im having a hard time locating some that people will hold up. Thank's in advance~
Old 10-17-2006 | 09:11 PM
blackdiesel's Avatar
Registered
I've put on 2 phat shafts, and I put the oil return line in the vice and heated it with the torch and bent it to fit, It will take a test fit or two, but it will all be worth it
Old 10-17-2006 | 09:27 PM
dzlfarmboy's Avatar
Yeah but i already cut mine a while ago when i put that B-1 on from Doug and i just got done replacing my hd gsk and o ringing it and the heater hose i used before was breaking down internally and im lookin for something that will take the heat and oil. Every where i've called said they dont think their hose will take it but there's got to be something out there.
Old 10-17-2006 | 10:35 PM
Registered
go to some where they make hyd. hoses they with have return line
Old 10-18-2006 | 04:31 AM
the_fox_man4's Avatar
if you really can't find any there is a shop in Salt lake city utah you can give a call the place is called EVCO House of Hose... 1 800 234 4673 . or 801 487 5721 they know what there doing. I have used them many times. it's bad when 5 auto parts/ farm supply stores say they can't get the hose or it doesn't exsist or I can adapt thouse fittings. I give evco a call 1200 miles away and they have my hose to me 2 days later.
Old 10-18-2006 | 06:27 AM
goosesgarage's Avatar
I just cut mine than went to a big truck parts store and got some 3/4" silicone heater hose. Its what big trucks use for heater hoses and what all the blue aftermarket turbo hoses fittings are. wont have any problems with it
txarrowhunter
03-20-2010 05:08 PM
whiskeyrichard
03-18-2009 04:10 AM
cootz
01-17-2009 09:42 PM
billmac
11-09-2008 02:33 PM
george7941
08-10-2005 08:06 PM
