which turbo do i need
Plan on putting 100 HP injectors on the whip. Got the stock turbo. Want a turbo that will support the power without to much lag. Any ideas? Looking to make like 400 or more horsepower
i have mach 2's (105's) and a S362.65.14 turbo. i am happy with it and on two different dyno's i did 436 & then 465 hp. drivability is good, but it takes some getting used too for sure. i can drive smoke free when i want too, and can smoke alot when i want too.
spool up is good, not excellent but good. pulls pretty hard on the top, again not excellent, but good. in the midrange rpm and power levels is where i like it (daily driving). i can turn everything down with the programming and it will be laggy, if everything is set to kill then it only gets hot at WOT. with the programming set at a moderate level, i never have to look at the pyro. for as often as i need to be at WOT - i can live with driving by the pyro on those occasions.
another good turbo choice which everyone seems to love is the garret ball bearing GT37__ . . . good luck with the decision!
Bradleysram
19
05-12-2009 08:36 AM
n0ne
16
11-08-2006 08:08 PM
blackdiesel
09-05-2005 12:17 PM
00turbo
05-28-2004 03:18 PM
