Turbo is chopping
Old 02-21-2007 | 08:52 PM
ct2500's Avatar
Turbo is chopping
my HTB2 62/14 makes a noise like it is chopping the air when iam in 6th gear like going 45mph and stand on it with the comp on 5x5 then it goes away by the time iam doing 60mph only does it when i realy labor the engine hard. has anyone experienced this?
Thanx Scotty
Old 02-21-2007 | 11:09 PM
n0ne's Avatar
mine did that .. but it was just the intake moving around..sounded kinda like.. barking the turbo.. nothing bad ever became of it.. ;/
Old 02-21-2007 | 11:16 PM
somis13's Avatar
that sounds like its "surging" that your describing. are you running a wastegate?
Old 02-21-2007 | 11:26 PM
TheBigNasty's Avatar
All turbos chop the air.
Old 02-22-2007 | 01:08 AM
Big Blue24's Avatar
What kind of RPM's are you turning at that speed?
Old 02-22-2007 | 03:46 AM
PourinDiesel's Avatar
Not enough drive to keep the charger lit. What you are describing is normally called "surge" or "compressor stall".
Old 02-22-2007 | 07:21 AM
ct2500's Avatar
around like 1250rpm
Old 02-23-2007 | 01:49 AM
NoSeeUm's Avatar
My DodgeZilla would do something like that at about 14-20 psi of boost under 5th gear low RPM throttle.
Sort of a ch-ch-ch-ch-ch sound?
Jim
Old 02-23-2007 | 02:36 AM
BCSCUMMINS's Avatar
Mine does it sometimes around 25-30psi I just push through it and it goes away.
Old 02-23-2007 | 03:09 AM
Big Blue24's Avatar
Sounds like surge to me, i know you paid big bucks for that turbo and you want it to run perfect everywhere, but you just can't lugg it that much with a load. Try another gear, more throttle, or if none of those are good options for you, buy a smaller turbo.
Old 02-23-2007 | 08:28 AM
Forrest Nearing's Avatar
just try a bigger turbine... you're trying to feed the engine more air than it can take, and it's like putting your hand over a vacuum, it speeds way up, then stalls... put a bigger hot side on it, and you'll have the thing balanced out better.
also, why on earth would you be in 6th gear at 45mph?
Old 02-23-2007 | 09:01 AM
ct2500's Avatar
i was just screwin around smokin out my buddys that were in back of me
Old 02-23-2007 | 11:44 AM
BigBlue's Avatar
If I'm cruising at around 1400-1500rpm I can hear my turbo ticking. It did it with my HY, my ksb-1, and now my ps62.
Old 02-24-2007 | 03:11 AM
NoSeeUm's Avatar
Yeah....
If you look at where you are at on the compressor map, don't be surprized if is right up there near the surge line. Low RPM high boost normally.
Jim
Old 02-24-2007 | 04:25 PM
somis13's Avatar
the only way to make the surge go away is to put more fuel in to the engine at that point. the engine is only letting so much through, and the turbo is supplying it with more air. and when it has no place to go the compressor wheel beats itself up or chops the air, making that "Brdrdrdrdrdrdrdrdr" sound that you hear. eventually it can bend the inducer blades on the compressor wheel backwards. have you considdered a blow off valve? Its like a waste gate but releases pressure on the intake side.
