Turbo Bark
Old 12-24-2006 | 10:43 PM
ct2500's Avatar
Turbo Bark
Now that i have my new turbo i noticed a lot more turbo bark is this bad for the new spinner??
Old 12-25-2006 | 01:14 AM
cumminsdriver635's Avatar
Its probably not something you want to be doing all the time, but if you have a pretty good turbo, it shouldnt be much of a problem.
Eric
Old 12-26-2006 | 11:08 AM
infidel's Avatar
You should avoid barking by letting off the throttle slowly. While I've only seen a couple of turbo shafts snap in half from it I've seen many factory airbox lids and BHAFs blown off from it.
Sort of a sick feeling opening the hood finding your air filter in the wrong place and realizing you've been sucking in dirty air for who knows how long.
Old 12-26-2006 | 11:47 AM
madhat's Avatar
Administrator/Jarhead
Is this something that can be fixed with a blow off valve?
Old 12-26-2006 | 12:46 PM
RowJ's Avatar
Originally Posted by ct2500
... turbo bark.... is this bad for the new spinner??
It's basically a compressor stall, which puts a heavy reverse load on your shaft, while it's spinning over 100,000 rpm.
Some major forces are involved, IMO.
As Bill says, not a lot of shafts get reported as breaking, but still, should be avoided as much as possible.
RJ
Old 12-26-2006 | 09:01 PM
Charlie8301's Avatar
yup, buy not worth the $600 IMHO
Randy
Old 12-26-2006 | 10:27 PM
dieselfan's Avatar
Originally Posted by Charlie8301
yup, but not worth the $600 IMHO
Randy
Randy, can you explain a little?
thanks, brian
Old 12-26-2006 | 11:08 PM
dbrick's Avatar
You can get a turbo guard which BD Performance sells or other brands that protect from turbo bark. Bds sell for around 6 bills. And yes it is bad to have it bark. Usually you can get away with it but it can break things also. A couple af years ago there were some threads on guys making their own. the turbo guards are basically a popoff valve that relieves the pressure at pre deremined settings
Old 12-27-2006 | 12:50 PM
aggiehorsepower's Avatar
if you got the b2 it is a pretty strong turbo and you shouldn't have to much of a problem if it barks. Those turbos are pretty much bullet proof lol
Old 12-27-2006 | 05:55 PM
600 Megawatts's Avatar
Muted User
A blow off vavle will not stop what people on here are calling turbo bark. Since there is no throttle on a diesel there is no rapid rise of compressor pressure like there is on a gasser when you get out of the throttle.
What diesel folks are calling turbo bark is nothing more than the turbo rapidly decellerating. When you get out of the accelerator pedal, there is immediate cessation of fuel burn in the engine and thus there is a rapid drop in the turbine power output due to the dropped EGT, pressure and volume of exhaust gas flow, and since the turbine no longer is supplying enough power to operate the compressor at high speeds, the turbo rapidly decelerates due to the great resistance of the compressor operating at speed. And there is no torque reversal either, its in the same direction.....
Kp
Old 12-27-2006 | 06:57 PM
Kp
Seems to on mine. Although it's not opened by a spike in intake pressure, instead ran buy a controller monitoring apps.
Randy
Old 12-27-2006 | 11:35 PM
Muted User
Randy
Well if its controlled by a device looking at the accelerator pedal position, then it would work ! Didnt know they were making them like that. Thought they were just pressure operated like the gassers..... my bad...
But, I must still say, that the bark is not a bad thing on a diesel. I believe this myth got started when guys were breaking HX40 shafts.... Stock HX40 shafts tend to break in a high boost applications, and with high boost you get loud barks, and so the breakage got associated with the bark.... There is no torque reversal on the turbo shaft with a bark...
Kp
Old 12-28-2006 | 12:52 AM
NoSeeUm's Avatar
Kp
I believe that RJ was refering to thrust reversal not torque reversal. This is cause primarily by the reversal in direction of the air flow from the high pressure in the manifold back through the compressor into the air filter. I am going to guess that the stall cavitation forces and the flexation forces on the compressor blades could be pretty significant under certain conditions. Especially if the turbo is already at or over rated RPM. Do it enough times and a blade or a bearing might fail.
Also keep in mind that the net thrust on turbo shafts is relatively small. That is because of the equal thrust aplied by the compressor in one direction and the thrust of the turbine in the other direction. The wheels are balanced so that these respective thrusts are equal and mostly counter act each other out. Push a compressor into stall almost instantly and its component of the thrust goes away almost instantly. Now the only thrust felt on the shaft is from the turbine. When the compressor comes out of stall, the whole process gets repeated in the opposite direction. These radical changes in thrust direction and magnitude have to be absorbed by the bearings.
As far as breaking shafts there could be significant torque type forces on the shaft in relation to the compressor and turbine ends. As the compressor blades go in and out of stall, they conversely go in and out of a loaded / unloaded condition. Unloaded during the stall, loaded (overloaded) recovering from the stall. From the turbine end, the shaft would get rotationally loaded and fulling unloaded almost instantly. You can see how this would cause pretty severe and rapid rotational torque as well as longitudenal thrust surges on the shaft itself. As well the probability of some really rapid RPM changes both acceleration and deceleration as the load / unload process occurs. My guess is that the shaft would most likely snap during a rapid deceleration, at high RPM, as the compressor suddenly is able to "bite" into the air again when it comes out of stall.
Jim
Old 12-28-2006 | 03:45 AM
Artsi_L's Avatar
Compressor stall and surge is an interesting phenomena. The net is full of explanations and studies over this issue. Here are just few links.
"Experts in 'compressor surge'Definition:
A disturbance occuring in gas compressors, especially centrifugal compressors, due to excessive pressure across the compressor in which the compressor blades stall and air flow suddenly drops. The flow can fluctuate and the compressor be damaged. It is the point of instability at which a compressor surges across, trying to reestablish its point of stability. "
http://www.intota.com/multisearch.as...mpressor+surge
http://www.airforce.forces.gc.ca/dfs...05/Jan05_e.pdf
http://en.wikipedia.org/wiki/Compressor_map
Old 12-28-2006 | 11:30 AM
Muted User
Jim
Very well said. I would agree 100% with all your comments, a very intelligent dissertation indeed. Flow reversal and subsequent compressor stall is the real issue at hand, not torque reversal. And your absolutely correct in that the compressor coming in and out of stall would set up rapidly fluctuating torque levels in the shaft, and albiet in the same direction, the fluctuating levels would begin a high cycle fatigue condition. The compressor stalling will also cause a thrust reversal as you stated, and I bet your correct in your assumption that this is where folks got crossed up and mentioned a torque reversal.
This was very refreshing to read through a subject matter on here and get some good technical explanations for things rather than listen to unsubstantiated wives tales.
Bravo!!! Jim and RJ!!
Kp
