turbo air guides?
Old 02-23-2007, 12:09 PM
dezrtdzl's Avatar
turbo air guides?
Hey I just clicked on the link for black cloud diesel and I was reading about turbo air guides, wondering if they really work or if that is something like that tornado thing? It sounds good in philosophy (its supposed to make the turbo spool faster and increase mileage/power), anybody know if it really works?
I have a 2002 2500, stock as you can get but looking to upgrade.
Old 02-23-2007, 03:51 PM
Ph4tty's Avatar
Its supposed to quieten turbo noise. How about instead of that remove the silencer ring for more noise instead. Take off the intake hose from the turbo and use a flathead screwdriver to pry the ring out on the turbo inlet. It'll
Old 02-24-2007, 09:50 PM
dezrtdzl's Avatar
does that do anything for performance? I would like to hear the turbo a little more.
Old 02-24-2007, 09:52 PM
Totallyrad's Avatar
The tag does help the truck pull a little better when towing. Other than that, I can't really tell any difference.
Old 02-24-2007, 10:07 PM
JPR Ram's Avatar
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Really? I do honestly think I get an extra pound out of the turbo. Maybe it's just my imagination, maybe not. But it does seem like it does.......
Old 02-24-2007, 11:08 PM
WUnderwood's Avatar
I ordered one because the turbo was driving me nuts. I think it does a LITTLE performance wise, and keeps the whine of the turbo to a dull roar, my personal opinion
Old 02-25-2007, 10:27 PM
Big Blue24's Avatar
So the tag does a LITTLE performance wise... just like a banks or swanker intake tube..... Save your money for more fuel or a bigger turbo!!!
Old 02-26-2007, 01:44 AM
Ph4tty's Avatar
Nope, but removing the silencer ring does sounds cool
Old 02-26-2007, 07:52 AM
Tiger Rag's Avatar
Contact DTR member rjohnson. He's got a spreadsheet on his tests with the TAG. He noticed lower egt's and less noise. Can't remember what else. His spreadsheets show some decent results.
Old 02-26-2007, 08:11 AM
Totallyrad's Avatar
One thing I'm puzzled by, when I ran the tag I had a surge on hard acceleration. In order to use the tag in the stock intake tube you have to remove the plastic fins in the tube. If I remember correctly, that bend is slightly more than 90*. I'm thinking the air is stalling slightly, causing the surge, hence the reason for the fins in the stock tube. I purchased an AFE torque tube to smooth out the bends and because it is supposed to allow you to run the tag, it won't. I'm working on modifying the AFE to make it work with the tag. I think that will eliminate the surge.
Old 02-26-2007, 08:23 AM
RustyJC's Avatar
I've been running the TAG 1 for years and am satisfied with its performance. The 2nd generation trucks didn't have turning vanes in the inlet duct between the air cleaner and turbocharger, and I was experiencing turbo compressor instability when towing up grades in 6th gear around 2200-2300 RPM at or near WOT. In addition, with the BHAF, the constant turbo whistle and whine were drawing complaints from the wife on long trips towing the 5th wheel. The TAG took care of both issues. If you're thinking it's voodoo science, do a Google search on "honeycomb flow straightener" to see where the technology comes from.
If you're looking for mega-horsepower gains, your money is better spent elsewhere. If you understand what the TAG can do and use it to target specific issues, it's a worthwhile addition.
Rusty
Old 02-26-2007, 08:32 AM
Totallyrad's Avatar
Rusty, I agree and it will definitely quiet down the turbo.
Old 02-26-2007, 10:21 AM
eichhoma's Avatar
Dont mean to hijack but I have a question on this.... will doing that cause any other issues; trouble codes or anything? I am considering doing that and hear that all does it just make the turbo whistle a little more, but want to make sure there is nothing else I should be concerned about in doing that.
When you pull the intake hose off the front of the turbo, where exactly is it and do you just pry something out?
Thanks!
Old 02-26-2007, 11:28 PM
Ph4tty's Avatar
Nothing to be concerned about. Just pull the hose off the turbo and look inside and there's a ring. Carefully pry it out. Its that easy.
Here's a link http://www.dodgeram.org/tech/dsl/FAQ/turbo_faq.htm
WithAnd without
Old 02-27-2007, 08:22 AM
eichhoma's Avatar
WithAnd without
Cool! thanks for the pics... I think I will do that this weekend and see how it sounds!
Quick Reply: turbo air guides?
