Turbo
Old 10-01-2008 | 07:45 PM
CTD01's Avatar
What I meant was can this turbo be used a bottom turbo? and the 62 as the top.
Old 10-01-2008 | 07:53 PM
Adam3291's Avatar
Ohhhhhh, no I wouldn't. An S400 would be the best for the lower turbo. The 66 is pretty much a big single charger. You wouldn't be able to tow with a 66 but it would move a good amount area by itself.
Old 10-01-2008 | 08:26 PM
bent valves's Avatar
My curiosity got the best of me and I looked up how cast iron and stainless steel compare for heat transfer. Cast iron will transfer heat more than twice as much as stainless if they are the same thickness. So if the stainless is thicker it will beat cast iron by a lot in retaining the heat.
The Coefficient of thermal conductivity of cast iron is 55 and stainless is 25.
http://www.roymech.co.uk/Related/Thermo.html
Old 10-02-2008 | 10:27 AM
clowndodge01's Avatar
Originally Posted by Adam3291
62/65/14 or maybe a 62/71/14 is the biggest I would want to run pulling.
these will both bold right on right no extras needed?
Old 10-02-2008 | 01:50 PM
CTD01's Avatar
Yea besides an hx40 down pipe.
Old 11-25-2008 | 10:36 PM
CTD01's Avatar
Why cant I make a twins setup out of my 62/65/14 and my 66/71/13? Also would it help to get a 16cm housing?
Old 11-26-2008 | 11:19 AM
Mike D's Avatar
The bottom charger has to feed the top, so you'll need more air coming from the bottom charger so the top charger has air to compress. At least that's my simple minded understanding.
Old 11-26-2008 | 02:25 PM
CTD01's Avatar
More air than my 66?
Old 11-29-2008 | 03:30 PM
CTD01's Avatar
I see that the bd kit is 2 s300s.
Old 11-29-2008 | 07:34 PM
97 D-Tec's Avatar
i dont think so.. the bottom charger is actually quite huge compared to what it looks like in bds picture
Old 11-30-2008 | 12:19 AM
dieselman2300's Avatar
Actually, BD towing twins ARE 2 S300.
One I think is a 57 with a 12 housing and the other is a 66 with something like a 17 or 18 housing.
Old 11-30-2008 | 12:37 AM
Just did some research and the BD towing twins standard set is 57/65/mm 0.80AR over a 66/73mm 1.10AR, the compressor cover on the secondary is 0.50AR and the compressor cover on the primary is 0.53AR.
The bottom turbo is a 22cm and the top is a 14cm.
Old 11-30-2008 | 10:39 AM
Ph4tty's Avatar
I thought .80 was considered a 14 cm^3?
The larger housing would help, but this is pretty far from ideal. Even with a bigger housing the ball park hp guestimate is twins make 85% the power of the big turbo used as a single, so you'd be losing power.
Old 11-30-2008 | 01:51 PM
Yep your right, I mistyped that. It is a 14cm housing.
Old 11-30-2008 | 10:40 PM
Tate's Avatar
Pretty sure the little guy is a S257, not a 300 series turbo.
