Turbo
There is no real advantage between a WH1C and a HX35. The only real difference is the method the compressor housing is attached, the WH1C has a v-band clamp that holds the compressor housing to the back plate and the back plate bolts to the center section. The HX35 uses a snap ring to hold the compressor housing to the back plate and the back plate is cast as part of the center section.
j
01-09-2004 09:19 AM
Haulin_in_Dixie
07-21-2003 12:14 PM
redram
12-10-2002 10:54 AM
