Turbine housing???
Turbine housing???
Would the 16cm turbine housing from TST be enough of a boost gain to accomplish 450 hp or would I need to go with a better turbo?? And is that is the case what is a good single turbo to upgrade to?? That doesnt cost an arm and a leg Any help please????
A housing isn't going to do much for 450hp. You will need a turbo.
And much slower spool. You need something around the size of a HX-40. It has a 60mm wheel. You can get an upgrade for your turbo from HTT to put a 60mm wheel on your turbo. And yes the H1C, WH1C, HX-35, and HX-40 use the same exhaust wheel and shaft so having a full 40 dose not make it any stronger than a hybrid. But you can use a 14cm exhaust housing and get good EGT's and fast spool. With a full 40 you can only go down to a 16cm and it had to much lag on a friends truck.
SuperDave4x4
07-24-2005 08:26 PM
600 Megawatts
01-30-2005 10:51 AM
dart440_72
07-10-2003 08:00 PM
