tuner blues
tuner blues
I just tried putting a Juice w/ attitude on, and now my truck wont start. It's a 99 w/a 5spd. I did not hook up the tranny line, or the egt line. The vp44 tap line also came undone. I've bled the lines and still nothin. Any ideas? Thanks, Andrew
I unhooked the box, still nothin. The attitude powers up and everything, but nothin. I looked at the fuel filter, and it didn't look bad at all. I think I might just have to take it to a diesel shop and fork over an arm and leg.
If it was running B4 you got in there messin' around, go back and undo everything, hook stuff up like it was - don't go second-guessing here - pretend you don't even have the module, and reconnect all the oem connections - don't even leave the box ground wire connected - remove the box and wires from the cab and lay it back in the bed - once everything is restored, give it a crank, see if it runs.
Or, check the fuses, incl those in the side panel
Well I got my truck back from the diesel shop today. I guess I unhooked a cable somewhere and forgot to plug it back in. There was also a diablo power puck on there too, that I did not see somehow. It must have been really hidden away somewhere. The lift pump was also changed too. I'm just happy that I found someone to fix my fudge up. I also found out that I can't get traction on L5 too...
