TST stacks
TST stacks
What are some of the other boxes people have stacked with the TST box other than the edge ez and the smarty??
I know that the smarty stack is probably the best but I can get a good deal on a edge ez.
Some really, what is the difference between the ez stack and smarty stack, are far as dyno numbers and sop dyno??
I would think the smarty would have more down low than ez but I would think the ez would make more power on a dyno.
I would also just like some of the other stuff people ahev stacked with them.
What, drag comp/ez mode, van aken (is that box any good) and what else??
Hum, never thought about the power puck.
Really I'm lookin to see which "little" box will the give the most timin.
I'm thinkin the more timin I can get the more power i can get, does that sound right???
What are some more no wire tap boxes/programmers that have boost foolin???
I think that most of the timing boxes are rated pretty close to each other. BullyDog has a timing chip with a three position settings. I think that the smarty will be the best though, it has timing and alot of lowend grunt. I have a MAD ECM on my truck without timing and adding that made a night and day difference.
Well thats just what I thought.
I think I'm gonna go with the old setup for a while EZ/TST stack.I know it works great if you just have a clutch that will hold it.
Something to consider is that if you think you might want more down the road, you could get a Comp and just not tap the wire. It will function as an EZ w/o the wire tapped.
Airspeedy
15
08-03-2007 11:34 AM
nfsommer
21
04-04-2007 03:45 PM
rockittboy
02-03-2006 12:38 AM
Zino
08-15-2003 10:14 PM
