TST Products
TST Products
[undecided] Just received some literature from TST. Anyone running this product and what are your thoughts. The powermax 3 looks like a good product which has ten different stages and a digital pyro and boost guage and remote for on the fly changes. I am stock right now I figure a good start is the guages and later mods will follow. The price of this product is around $900 and adjusts from 13 hp 40lb to 120hp360ftlb. I am new to performance upgrades and learning each day. ;D ;D ;D
Re:TST Products
I have the PM3 Comp, 165 hp ;D. I have stock injectors and a Scotty II.<br>I am very happy with it so far. It is simpler than the Edge Comp, which has fuel and boost settings separately. The way Edge does it might be a good thing, I don't now, but I like the simplicity of the PM3. Also, I have heard from others, who already had Edge Comps, that they wanted to get a PM3. This suggested to me that the PM3 is better, but I can't say for a fact as I have never used the Edge Comp.<br>One other thing you need to be aware of is that while the Edge Comp can be used without punching the pump wire, equivalent to an Edge EZ. The PM3 must have the pump wire punched no matter what.<br>I have also noticed the the PM3 Comp needs to be on level 4 or lower when using the cruise control otherwise it surges because there is so much power for the same movement of the accelerator.<br><br>Chris
RockcrawlingTJ
12-26-2005 12:31 AM
Zino
08-15-2003 10:14 PM
