TST Powermax Vs. TST Powermax 3 Comp???
I'm so stupid.... The little plastic hose coming out of the head was partially broken. I pulled it off, cut off 1" and re-connected it. 42 psi, just like the TST R46 was showing. There, I'm a bone head....
Big Blue said same thing when he switched to TST! He also said TST pulled harder which would make sense if less smoke (better fuel burn).
I never played with an Edge Comp so....??
RJ
RJ
I have Tst pm 3, and I dont get any smoke at all. I know it is a good thing, but if I put let say RV275 injectors or something harsher, what kind amount of smoke I get before spool up,or do I get any at all?
Oh yes! Pre Boost...all bets are off and smoke is definately there!
Don't know about 275's but my Mach 4's will give all I ever wanted.
TST Comp will give even more smoke...pre-boost because it fuels earlier. 1.5 psi vs 3 psi...IIRC.
RJ
RJ
My truck still smokes at low boost but clears up better than the Edge Comp. Can a guy compare stage 2 jammers to mach 4's or not even close???
