TST Powermax 3 COMP!!!.......WOW!!!
I just wanted to let yall know I officially have changed the sig. The PM3 makes my banks ottomind look like a pansie. I can't really describe it but all I can say is WOW
!!! It brings the fuel on low and I mean really low. Low enough to make a whole city block disapear in smoke. It keeps the power flowin all the way to 3300 rpm
. In one word "AWSOME"!!!
![Shocked](https://www.dieseltruckresource.com/forums/images/smilies/shocked.gif)
Re:TST Powermax 3 COMP!!!.......WOW!!!
I'm still at odds between that and a comp. Leanin towards the TST every minute. What is the advantage of stacking the EZ with it?
sparkchaser:<br><br>My son has a 2001 which has the TST PM 3 with an<br>Edge EZ Box "stacked" on top of it. He said that the<br>Edge Box puts more "timing" into the engine which<br>gave his truck alot more "bottom end" power. The<br>difference was very noticeable. <br><br>---------<br>John_P
You are exactly right. There is added timing along with a lot more fuel in the bottom end. My smoke went from minimal to super mesquito killer after I installed the EZ.
Is the performance that much more noticeable with the EZ installed or is it just a bit more? Just wanting to go from a comp to a TST comp 3 and not sure if its the right move?<br>
Jamie I would say that there is a significant enough difference to stack it with either a VA or EZ box. There is only a slight difference at the high end but you can tell a big difference at the low end.
dodgediesel
54
03-17-2007 08:40 AM
dodgediesel
17
11-18-2006 12:47 AM
CTD2001
84
08-13-2006 10:33 PM
gandrews
16
09-21-2003 08:18 PM
