tst pm3 / tst pm3 comp
Originally Posted by CTD2001
"The PMCE (Competition) adds 180 HP and 450 lb-ft Torque (on level 9) for the standard engine. The HO (High Output) engine.... does not make as much of a difference and adds 80HP and 310 lb-ft of Torque."
I was wrong above anyway.... the PM3 is rated at 135 hp. (15 hp per setting x 9 settings). I get 120 hp on my automatic. The Comp only adds 30 hp max for me, so far, on the dyno!
RJ
Originally Posted by possum67
...havent noticed mine shuddering when i let off the throttle. is that a normal thing with the tst comps?
RJ
I can get the shudder and BAD! But the only time I get it is if I back out of the throttle quickly BEFORE the turbo has fully lit. If the turbo is lit and boost is up, I can snap out of the throttle, no problem. But if I have it floorboarded and the coal is rolling, but the turbo hasnt lit yet and then roll out of it, it shudders real bad. I am convinced that the shuddering is NOT the pump cavitating, but the engine shuddering from buring the residual fuel left in the cylinders in an un controlled and un timed fashion. It actually sounds very cool but I dont suppose its the best thing for the engine.
Kp
Kp
Registered
The PMCE (Competition) adds 180 HP and 450 lb-ft Torque (on level 9) for the standard engine. The HO (High Output) engine (2001-2002) already has 245 HP and the PMCE (Competition) does not make as much of a difference and adds 80HP and 310 lb-ft of Torque.
Originally Posted by 600 Megawatts
I have heard that the regular PM3 only adds 80 Hp to an HO as well.
The weenie HO vp is simply maxed out with the regular PM3, so pushing it harder gets you nothing.
That said, you should still be able to get ~500hp pretty easily with a TST and some decent sticks, assuming enough air.....
jlh
With my current setup on the normal TST, I'm not seeing a difference between level 4 and level 9.
The 434 in my sig was done on level 4 and my level 9 run only made 429.
It is good, i like it alot, have not had to much time to drive the truck around, i usally get my seat time with it on the weekends and drive the 1990 toyota 4runner for work during the week. I am looking forward to the weekend to get out and play with it some more. Did you order yours?
waiting till friday. if i still have no offers on my DRAG comp then i am just going to keep it and sell it at a later time if any. so i am going to order friday and i will have it for next weekend.
good deal, did you see the one on TDR? here is the link http://www.turbodieselregister.com/c...rmat=headlines
Item number 15
Item number 15
