TST j-Hook Questoins???
I researched this once before but can't seem to find any of the threads and can't remember the info. that made me want to install it. I'm wanting to install this weekend and I'm wondering what the results/benefits will be and if there will be any noticeable difference after install???
I just installed one and it improved my boost by about 9psi WOT. I see you have a juice so you should have the boost elbow already, not sure on your turbo but if you don't have the boost elbow the J Hook is about the same net result. If your trying to "stack" an elbow and J Hook I would just watch your boost gauge, I'm only guessing but would expect the elbow to work normally (increasing pressure) and then the J Hook would engage after = higher boost readings. For the prices its a nice toy.
Good luck.
Good luck.
