Tst Grabber
Tst Grabber
Got a new Vp44 pump from the dealer this past week, now the BD pump cover that i have will not fit on the new pump, the holes do not line up well at all, and the unit does not seem to want to sit flush, so instead of trying to force it, i just put the stock pump cover back on. Will the TST Grabber work with and Edge Comp, or will they only work with a TST product? Want to tap the wire on the pump, but do it in a way that if i have another pump failure, i can remove it and the dealership will not now that it was tampered with. Thanks for the Help
The dealers are most definitely trained to look for pump wire piercings - whether its from the TST grabber or others.......they will likely find it.
Finding the hole from a grabber takes more than just a visual inspection...and , IMO is not easy to catch. However, I have never tried to "fool" a dealer...so I don't really know. My dealer knows what I have done and works with me...whenever he can.
Best reason for using the grabber is excellent contact with the IP wire without it being more or less permanent.
RJ
RJ
rementa
06-01-2005 03:18 PM
