Trucks Getting Dyno'd This Weekend, Tips?
Good evening guys. I'm getting the truck Dyno'd this weekend and was wondering if there is anything I should know, tips, advice for maximizing how much power I get out of the truck? Thanks Tye
4th gear, 1200rpm pin it, roll into it, try it all if you have the time. You can try 5th but you dont have a big laggy turbo so it probably wont help any.
Putting some 265's on the rear will up your numbers a little too. Maybe air down the rears a little to reduce slippage.
What kind of dyno is it?
If you air them up to maximum rated pressure, you will minimize the rolling resistance of the tire, ensuring that more HP gets to the rollers instead of being eaten up by the tires and converted to heat.
JMO
jonny mopar
Competition / Pulls / OffRoad
08-27-2009 05:56 PM
Fueling around
04-24-2008 02:55 PM
CTD_Neil
01-05-2005 02:52 PM
