truck stalls and has lopey idle
Old 04-19-2008, 11:32 PM
taken5875's Avatar
Question truck stalls and has lopey idle
I just had injector nozzles put in by a professional who I trust very much that he totaly knows what he is doing so I really don't think there is any error on his part so try to start looking at other possibilitys. not that I am a mechanic but I watched him pressure test them for leaks @ 4000psi and then he pop tested them 5 popped rite @ 4500 and one @ 4400 the truck runs strong with no stumble at all but at idle it sounds like a v8 with a cam and some times it will stall when you put it in to gear.
Old 04-20-2008, 01:49 AM
Fishin2Deep4U's Avatar
Are all the coppers in? Any double stacked? Or missing?
I would look there first. Sounds like a high pressure leak.
Dave
Old 04-20-2008, 02:04 AM
taken5875's Avatar
as far as seeing a leak goes I cant see one. or would it be leaking internally were I could not see it.
Old 04-20-2008, 11:18 AM
rebal's Avatar
if its leaking internally watch your oil it will rise and smell like diesel
Old 04-20-2008, 03:21 PM
99globalwarmer's Avatar
its nozzle lope it seems to happen all the time, the pops need to be closer,
Patriot
04-17-2006 08:44 PM
Hounddog
02-14-2006 06:33 PM
silver_goat
11-05-2004 02:50 PM
MIKE,J
08-29-2003 09:26 AM
98rammer
05-25-2003 09:31 PM
Quick Reply: truck stalls and has lopey idle
