Truck Died
Old 01-05-2006 | 08:03 PM
mx yfz 450's Avatar
Truck Died
I Was Driving Last Night About 65 And Then I Went To Wot On 1x1 And Went To About 80 Then Put It In Netural And Started To Coast And The Truck Died. I Was About 1200egt When I Let Off And 18 Psi Fp. I Pulled Over And Hit The Starter Real Quick To Get Fuel Pressure On My Gauge Was About 20-21 And Then Hit It And It Didn't Want To Start Right Away Then It Fired Up And Has Ran Good Ever Since. I Have A New Intank Pusher Pump New Vp44 And New Holly Blue Pusher Pump. What Do You Think Could Be Causing This. If It Is My Vp Do They Have A Warranty Of Any Sort It Is About 4-5 Months Old And Has About 8k On It And Thats All. Thanks Skyler
Old 01-05-2006 | 08:41 PM
crobtex's Avatar
I don't know where you bought your VP, but from what I have read, most all have a one yr warrenty.
Old 01-05-2006 | 09:49 PM
ratsun's Avatar
______________________________________
Or until the wire taps
Old 01-05-2006 | 10:19 PM
99 cummins's Avatar
Fuel pressure sounds awfull high to me, I'd think a regulator would be in order.
Old 01-05-2006 | 10:40 PM
BigBlue's Avatar
My old roommate's been running 25 at idle and 12 at WOT for a year now without any problems. I used to run 20 at idle and 18 at WOT with my old PE pump. Ran it for a year before it died on me.
Old 01-05-2006 | 10:56 PM
99 cummins's Avatar
You all know I don't pretend to have a clue about anything mechanical, but I do lay claim to a very small amount of common sense. It would seem to me that with the combination of fuel pressure that high, stage 5 jammer injectors and the comp, when you came off the fuel that quick and put it in nuetral the cylinders would be washed out with a huge amount of fuel already en-route through the pump when you let off.
Old 01-06-2006 | 12:13 PM
mx yfz 450's Avatar
Yeah it only does it when i'm hard on it and then put it into netural. If i leave it in gear i have no problems. I don't have any codes either.
rip 112
13
09-09-2013 11:27 PM
Tommy93w350
20
11-02-2005 12:07 AM
DRD
15
04-06-2003 08:59 PM
bdog
03-05-2003 01:37 AM
Desert Diesel
12-06-2002 04:54 AM
